15 years agoFixed-point multiplication with "altmult_complex" megafunction
Hi, I am using the altmult_complex (complex multiplier) with inputs dataa (both real and imaginary) having 16 fractional bits, and inputs datab (both real and imaginary) having 2 decimal bits a...
15 years agoI tried the megafunctions and observed exactly what you both, rbugalho and FvM, stated.
I will try outputting the entire output range (depending on my input ranges) using altmult_complex and then just select the MSB by discarding the LSB. Thank you all for your diligent guidance and help.
