15 years agoFixed-point multiplication with "altmult_complex" megafunction
Hi, I am using the altmult_complex (complex multiplier) with inputs dataa (both real and imaginary) having 16 fractional bits, and inputs datab (both real and imaginary) having 2 decimal bits a...
15 years agoThe product of two 0.16 signed numbers is normally 1.31 in fixed point, I would expect the same shift to take place with altmult_complex, as long as no saturation logic is applied to the result. You may want to keep 17 bits and perform the saturation logic - a result with the MSB set has to be replaced by the most negative value, otherwise, the MSB can be cut.
