15 years agoFixed-point multiplication with "altmult_complex" megafunction
Hi, I am using the altmult_complex (complex multiplier) with inputs dataa (both real and imaginary) having 16 fractional bits, and inputs datab (both real and imaginary) having 2 decimal bits a...
15 years agoIf I understand well you have:
dataa on 16 bit in 2's complement fractional bit. Your maximum dataa value is: .0111_1111_1111_1111 = 0.25 - 2^(-16) = MaxA Your minimum dataa value is: .1000_0000_0000_0000 = -0.5 = MinA datab on 16 bit unsigned with 14 fractional bit. Your maximum dataa value is: 11.11_1111_1111_1111 = 4 - 2^(-14) = MaxB Your minimum dataa value is: 00.00_0000_0000_0000 = 0 = MinB Now you need to calculate the range of your output. The maximum value is: 2*MaxA*MaxB = 2 - something small The minimum value is: -2 + something small I guess that your output mustb be 2's complement with 2 integer bit and 14 fractional bit whose range is: 10.00_0000_0000_0000 = -2 01.11_1111_1111_1111 = 2 - 2^(-14) Please check if my calculations are correct. I made them very fast. Was this your question?
