10 years agofitting error
Hellow every body
During compilation of my design, I find an errore of "Error (170143): Final fitting attempt was unsuccessful" that the dveice canot rout some signals. Although the resources is small and doesnot fit the whole device. I tried to make changes in my design and recompile many times. but i face this error again. what can i do:(:(:(3 Replies
You didnt post the code for AES_package, C128RndkyGen and InvMixRndky.
Are you sure this is the correct code, as it contains syntax errors: ROUT 128 in the process should be ROUT128? I also note that there are 2 problems with your final process. 1. ROUT128 is not in the sensitivity list 2. It generates latches as you do not assign all bits of RKA128 in all cases. (latches are frowned upon in FPGAs because they can lead to timing problems). - Altera_Forum
--- Quote Start --- Without the code, we have no idea what could be the problem. Is it some large unpipelined logic design with feedback? Post the code so we can at least start to speculate. --- Quote End --- Her is may be the part of problem: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use work.AES_package.all; entity Expand is port( clk,reset : in std_logic; opsel : in std_logic; keylen : in std_logic_vector( 1 downto 0); Cipherkey : in c256key_type; RoundkeyArray : out RoundkeyArray_type ); end entity Expand; architecture Struct of Expand is ---------------------------------------------------- component C128RndkyGen is port( Round_index : natural range 0 to 10; Roundkey_in : in c256key_type; Roundkey_out : out c256key_type ); end component C128RndkyGen; ---------------------------------------------------- component InvMixRndky is port( clk,reset :in std_logic; Roundkey_in : in Roundkey_type; Roundkey_out : out Roundkey_type ); end component InvMixRndky; ---------------------------------------------------- signal control: std_logic_vector(2 downto 0); signal CREG,CNXT : natural range 0 to 10:=10; signal TRKA192 :Roundkey256Array_type; signal RIN,RREG,RNXT,ROUT128,ROUT192,Rout256 :c256key_type; signal FRKA,RKA128,FRKA128,DRKA128,RKA192,FRKA192,DRKA192,RKA256,FRKA256,DRKA256 :RoundkeyArray_type; signal Cipherkey_reg : c256key_type; begin process (clk ,reset) begin if reset='0' then Cipherkey_reg <= (others => (others => x"00")); RREG <= (others => (others => x"00")); CREG <= 0; elsif (clk'event and clk='1') then Cipherkey_reg <= Cipherkey; RREG <= RNXT; CREG <= CNXT; end if; end process; ---Common Resources control <= opsel & keylen; -- INPUT MUX RIN <= Cipherkey_reg WHEN CREG=1 ELSE RREG; --MUX1 WITH KEYLEN SELECT RNXT <= ROUT128 WHEN "00", ROUT192 WHEN "01", ROUT256 WHEN "10", (others => (others => x"00")) WHEN OTHERS; --THE COUNTER combinational circuit CNXT <= 1 WHEN CREG=10 ELSE CREG+1; RKA128(1) <= ( 1=>Cipherkey_reg(1), 2=>Cipherkey_reg(2), 3=>Cipherkey_reg(3), 4=>Cipherkey_reg(4)); Rndky128Gen : C128RndkyGen port map( Round_index => CREG ,Roundkey_in => RIN ,Roundkey_out => ROUT128 ); process(CREG) begin case CREG is when 1 => RKA128(11) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 2 => RKA128(2) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 3 => RKA128(3) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 4 => RKA128(4) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 5 => RKA128(5) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 6 => RKA128(6) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 7 => RKA128(7) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 8 => RKA128(8) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 9 => RKA128(9) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when 10 => RKA128(10) <= (1=>ROUT128(1),2=>ROUT128(2),3=>ROUT128(3),4=>ROUT128(4)); when others => null; end case; end process; end architecture; - Altera_Forum
