14 years agoFitter ignores fast i/o assignments.
Why does fitter ignore the sdram fast i/o assignment? The warning is: Warning (176250): Ignoring invalid fast I/O register assignments. See the Ignored Assignments panel in the Fitter Compilatio...
14 years agoQuartus can't promote registers to IO registers when:
for outputs: you read the output signal back in your logic for inputs: you use both registered and unregistered inputs in your logic
