15 years agoFitter could not properly route signals from DQ I/Os to DQ capture
hi all: I got a "critical warning" when i construct ddr2_controller using MegaWizard. the device is ep3c16f484. ddr2 controller pin is assigned at the bottom of the ...
15 years agohi all:
I generate a ddr2 controller which data wide is 32,then my fpga can connect to two ddr2 sdram.this controller is used to check my fpga pin assignment. no error, but this warning above!
