11 years agoFIR II MegaCore strange output
I generated a FIR Megacore from the IP catalog, and ran the generated simulation script to check its functionality. Here is what I got: http://www.alteraforum.com/forum/attachment.php?attachmentid=10242&stc=1 Well, it looks very similar to the impulse response, but I noticed breaks between samples... when I changed back to binary representation I got this: http://www.alteraforum.com/forum/attachment.php?attachmentid=10243&stc=1 There are zeros in-between samples! Can you explain this whether it is normal behavior or wrong usage (bearing in mind that I didn't change anything... it's the original script and testbench)3 Replies
have you considered valid out signal?
--- Quote Start --- have you considered valid out signal? --- Quote End --- Sir... you have no idea how much I appreciate you! Probably you've ended my one week pain! :D And as you say in kurdish... Sarsarim ;) https://www.alteraforum.com/forum/attachment.php?attachmentid=10244 - Altera_Forum
Bijit Kurd o Arab
