11 years agoFIR Compiler II TDM Problems
Hello I' working for the first time on a simple single rate FIR filter implementation with a 13 Bit input data stream. The filter works fine when I use the same frequency for the FIR clock and ...
11 years agoYes I have one channel with a data rate of 1.82MHz and the clock of the FIR filter is 116.48 MHz -> tdm factor of 64. I set the data valid input continous to high. But with thos settings the filter does not work correctly.
Sorry but I did not understand your whole answer. Is it right to put the valid input to 1 all the time? Or what do you mean with "make valid in 1 in 64 as well to indicate which data slots are valid"
