11 years agoFIR Compiler II TDM Problems
Hello I' working for the first time on a simple single rate FIR filter implementation with a 13 Bit input data stream. The filter works fine when I use the same frequency for the FIR clock and ...
11 years agoIf I understood you. You have one channel data but tdm factor 64 and input clk is 116.48MHz, data rate is /164 of that so you need to make valid in 1 in 64 as well to indicate which data slots are valid.
