12 years agoFIR Compiler and FIR feedback filter.
Hello guys, Today I'm trying implementing a FIR feedback in my design with the FIR compiler megafunction. I've created 25 8-bit coefficients and imported them in the FIR compiler tool. ...
12 years ago --- Quote Start --- try value of 10 only followed by zeros as above example then check how many zeros you get at output before 100 comes out. This way you rule out any scaling effect causing zeros at output. normally filters need registers at each mult and adders but for slow speeds one register might be enough --- Quote End --- So this is my output with only a 10 valued input: https://www.alteraforum.com/forum/attachment.php?attachmentid=8516 It seems it leads to the same problem..
