16 years agoFFT Megafunction Fixed Point
I'm trying to use Altera's FFT Megafunction in Fixed Point mode but I didn't find any documentation defining how many bits it uses for decimal part. I'm using the Variable Streaming because its the o...
16 years agothe FFT core only has a sense of decimals when using floating point mode. fixed notation is largely an abstraction
since the FFT is a linear operator, you should be able to imagine multiplying your 26:6 input word by 1,000,000 to force it to 32:0, a full integer. then you can divide the FFT output by 1,000,000 to rescale the FFT output is somewhat relative due to processing gain and any windowing. if you convert to decibels you could just subtract 20*log10(1,000,000)=60dB from each value
