11 years agoFatal Error: Int Divide By Zero
It's driving me crazy. I couldn't figure it out what is the problem. I mean, all versions of quartus 2 (ver 8,9,9.1,9.2,10.0,10.1... trust me I downloaded and tried all)
shows me this one: there is no exception. --------------------------------------------------------------------------------------------------------------- *** Fatal Error: Int Divide By Zero Module: quartus_map.exe Stack Trace: 0x258e4: GEN_MACHINE_INFO::get_cache_size + 0x3b4 (CCL_GEN) -------------------------------------------------------------------------------------- Info: Command: quartus_map --read_settings_files=on --write_settings_files=off lab1 -c lab1 ----------------------------------------------------------------------------------------------------------------- End-trace I have no idea what is wrong with mine... I just bought this laptop 2 months ago settled with window 8. I used to use this tool with my old ones. I would really appreciate it if you give me some solutions to make. Thank you. Hope you're having a great day. edit - no private emails5 Replies
Post the code on here, so we can look at it.
Whatever code I put on, this warning sign keeps popping up...
I just put one input and output with 1 and2 gate to check if the program works out. *** Fatal Error: Int Divide By Zero Module: quartus_map.exe Stack Trace: 0x258e4: GEN_MACHINE_INFO::get_cache_size + 0x3b4 (CCL_GEN) End-trace -------------------------------------------------------------------------------------------- Info: Command: quartus_map --read_settings_files=on --write_settings_files=off lab1 -c lab1 -------------------------------------------------------------------------------------------- - Altera_Forum
I suggest raising a ticket with altera mysupport
This error relates to Quartus II internal error. It is generally recommended to report this to Altera and seek for their advice on workaround.
