14 years agoFastest 16bit parallel port (3.3V)
Hello everyone, I am trying to build a kind of an All-Digital-PLL using a DDS from Analog Devices. The DDS allows programming the output frequency by using a 8bit or 16bit parallel port, wh...
14 years agoThanks Dave,
the device is AD9910 and it uses a LVCMOS 3.3V interface. If the 250MHz is not achievable, I would settle for a device that can use the 250MHz Pclk provided by the AD9910 and produce data at half clock rate (i.e. 125MHz). Regards, Dorin
