14 years agoFaster: reg mem[] or M9K?
I'm not meeting timing on my design. It takes over 8ns to pull data out of a 'reg' based 128 deep mem[] (see attached Timequest report). I'm considering ways to speed things up and use of M9K blocks ...
14 years ago --- Quote Start --- The huge mux chain involved with a register based memory array will considerably slow down the data access. Block RAM is faster in this situation. --- Quote End --- Yes, this is exactly what i suspected but needed to have it confirmed before putting in work to convert my reg based mem array design to use block RAM. Can you tell me what I need to do to make my verilog "compliant" with the QII requirements such that I can convert my mem[] based design to use M9K storage? Would use of a HDL template as the one shown below make this use M9K blocks?
// Quartus II Verilog Template
// Simple Dual Port RAM with separate read/write addresses and
// single read/write clock
module simple_dual_port_ram_single_clock
# (parameter DATA_WIDTH=8, parameter ADDR_WIDTH=6)
input data,
input read_addr, write_addr,
input we, clk,
output reg q
// Declare the RAM variable
reg ram;
always @ (posedge clk)
begin
// Write
if (we)
ram <= data;
// Read (if read_addr == write_addr, return OLD data). To return
// NEW data, use = (blocking write) rather than <= (non-blocking write)
// in the write assignment. NOTE: NEW data may require extra bypass
// logic around the RAM.
q <= ram;
end
endmodule Tricky, I can't pipeline my design further because the failing path shown by the TimeQuest screenshot is actually just to get the data out of the array and into the target register (i.e. reg [31:0] reg_rx_tlp_bus <= mem[index]; ) EDIT: I'm looking into using a Megawizard-generated "Simple Dual-port RAM" in my design. It should work fine since my memory actually need to write 64-bits but read 32-bits. I will have to do a fair bit of redesign and re-testing but it should be worth the work if it results in significantly better performance. Previously, I had to pipeline my design just to get the data out of my array-based memory in one cycle. I'm hoping to be able to gain one or two clocks of performance per read in the new design.
