14 years agoFaster: reg mem[] or M9K?
I'm not meeting timing on my design. It takes over 8ns to pull data out of a 'reg' based 128 deep mem[] (see attached Timequest report). I'm considering ways to speed things up and use of M9K blocks ...
14 years ago --- Quote Start --- Will use of M9K RAM blocks significantly speed up the design compared to storing data in regular registers (i.e. 'reg')? --- Quote End --- The huge mux chain involved with a register based memory array will considerably slow down the data access. Block RAM is faster in this situation. RAM inference coding "style" reflects primarly hardware requirements. The first point to find out is if the intended design topology is implementable with block RAM or can be modified accordingly.
