11 years agoFast Passive Parallel x32 for Cyclone V and FPGA configuration by the HPS
I am referring to the link below
http://www.altera.com/literature/hb/cyclone-v/cv_54013.pdf and with respect to this Chapter 4-6, Table 4-1:Configuration Schemes for FPGA Configuration by the HPS with respect to this link: http://www.altera.com/support/devices/configuration/schemes/cfg-matrix.html My question is why is it that in the second link, it indicates FPPx32 by Cyclone V is not supported. But in the first link under table 4-1 shows that it is possible to configure in FPPx32? Why is there this conflict. I need to understand because the second link is consistent with the behavior in Quartus II version 14.0 and 13.1 when I try to create the rbf file, it says the mode is not support. But then if that is the case, my biggest confusion is when working with the DE1-SoC kit, under the HPS_LED_HEX example, the rbf file is converted from the using FPPx32 compression enabled. My 2 questions are 1: how do I convert to in FPPx32 from my sof to rbf file with Cyclone 5 device. and 2: how do I enable compression mode. Because there is no option for me to enable compression. The button to click that does not work... Anyone encountered this issue before?No RepliesBe the first to reply
