12 years agoFan-out too weak to trigger SignalTap II ??
I set up two instances in signaltap, one instance contained a signal that would trigger acquisition at rising edge, the other instance contained the same signal but would be triggered by something el...
12 years agoHi zoomkrupesh, I used the working frequency for both instances. It seems I can only select a clock signal instead of typing in a frequency manually. Is this the correct way to do it?
