12 years agoFan-out too weak to trigger SignalTap II ??
I set up two instances in signaltap, one instance contained a signal that would trigger acquisition at rising edge, the other instance contained the same signal but would be triggered by something el...
12 years agoWhat is the sampling frequency of the first instance? Is it enough to capture the rising edge of the signal?
