MIT_R_D
5 years agoFacing Issue On Design Example: Intel Arria 10 FPGA Remote System Update via PCI Express*
Hi I am trying to emulate the Design Example: Intel Arria 10 FPGA Remote System Update via PCI Express*. i am facing issue when we trying to download any application can anyone help me on this? ...
NurAiman_M_Intel
5 years agoHi,
Can you try to test the design with the jic file first.
- Program the Flash with the jic file shipped with the design.
- Shut down the system and then power on again, observed four red LED lit on.
- Install the driver and run the application, select not to download the application image.
- Select reconfig the FPGA, use start address 0x2000000 or 0x4000000
If this is working, then the hardware is good for further testing.
Aiman
- MIT_R_D5 years ago
Hi
Yes,
As I mentioned in my first post I am able to swap the application through PCIe using driver and application which we downloaded through JTAG.
We are able to swap the application and factory image frequently without any issues.
We don't have issue with setup or hardware. Same setup used for PCIe based user projects
