F-Tile PMA Direct PHY - USB3 - Enable per PMA lanes TX and RX ready signal issue
We are using DPHY IP configured for USB GEN1&GEN2 - Quartus 23.4
DPHY Configuration : USB , 2 lanes , Enable per PMA lanes TX and RX ready
When training link at GEN1 for 2 lanes it seems that rx_ready of second lane stay de-asserted.
looking at DPHY IP on the following files we found the issue:
*_directphy_f_*.sv
// wire [num_sys_cop-1:0] int_rx_ready; // Generated IP
wire [ready_width-1:0] int_rx_ready; // Should Be
directphy_f_sip_*.sv
//.dphy_reset_status_tx_ready_i (tx_ready), // Generated IP
//.dphy_reset_status_rx_ready_i (rx_ready), // Generated IP
.dphy_reset_status_tx_ready_i (&tx_ready), // Should Be
.dphy_reset_status_rx_ready_i (&rx_ready), // Should Be
Attached DPHY IP with READY signal issue.
Just to mention that although I fixed it the RTL it is functionally not working well.
rx_ready signal of second lane fail unexpectedly and afterward rx_ready of first lane fail also.
Shaul
- Kshitij_Intel
In Q23.4 USB option and support has been removed. I opened your shared .ip in Q23.4. You are getting an error USB is not an option now. Sharing the screenshot below.
Thank you,
Kshitij Goel
- shauls
Hello Kshitij ,
I have an *.ini file that enable USB on Q23.4.
I can send it to you by Email
Shaul
