14 years agoExecuting tcl to a specific project
I am new to tcl scripting and I am having a really hard time understanding how to execute a tcl script. I have the project open in quartus and the tcl script in the same directory as the project. The scripts does virtual pin assignments and I took it as it was from the altera website. Thank you, -Adrian2 Replies
Thank you Dave. Very clear and concise answer.
--- Quote Start --- I am new to tcl scripting and I am having a really hard time understanding how to execute a tcl script. I have the project open in quartus and the tcl script in the same directory as the project. The scripts does virtual pin assignments and I took it as it was from the altera website. --- Quote End --- Tcl scripts can be 'sourced' from a Tcl shell. In the Quartus GUI, click on the Tcl shell. If you can't see the shell, make it visible using View->Utility Windows->Tcl Console. Then at the Tcl prompt (which looks like tcl>) type: tcl> source my_script.tcl where my_script.tcl is the script you are trying to 'execute'. What you are really doing by sourcing the script is saving yourself some typing. If the script defines a procedure, eg., something like this proc boring {} { puts "This is a boring procedure!" } Then it defines a new procedure in the Tcl shell. You can then type tcl> boring and the shell will run the procedure, which prints a message to the console. If you want to see more complex use of Tcl scripts, go through this tutorial: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers, Dave
