14 years agoExample project for Arria II GX dev kit
Hello all. Does any have an example project for Arria II GX dev board (EP2AGX125 version) that includes all peripherials installed on the board? Thanks.
14 years agoSolved. The problem was in SOPC-system addressing. (28-bit GCC warning in Qsys).
I remap modules addresses, rebuild, recompile and download project to board. It work. But didn't ping now :) Log:
Calling alt_main.
Entering alt_main, calling alt_irq_init.
Done alt_irq_init, calling alt_os_init.
Done OS Init, calling alt_sem_create.
Calling alt_sys_init.
Done alt_sys_init.
Redirecting IO.
Calling C++ constructors.
Calling atexit.
Calling main.
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Can't read the MAC address from your board. We will assign you
a MAC address.
Please enter your 9-digit serial number. This is printed on a
label under your Nios dev. board. The first 3 digits of the
label are ASJ and the serial number follows this.
-->Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
497852135
497852135
Your Ethernet MAC address is 00:07:ed:ff:9e:e7
Static IP Address is 192.168.1.2
prepped 1 interface, initializing...
INFO : TSE MAC 0 found at address 0x10002000
INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group
INFO : PHY - Automatically mapped to tse_mac_device
INFO : PHY - Restart Auto-Negotiation, checking PHY link...
INFO : PHY - Auto-Negotiation PASSED
MARVELL : Mode changed to RGMII/Modified MII to Copper mode
MARVELL : Enable RGMII Timing Control
MARVELL : PHY reset
INFO : PHY - Checking link...
INFO : PHY - Link not yet established, restart auto-negotiation...
INFO : PHY - Link established
INFO : PHY - Speed = 1000, Duplex = Full
OK, x=17, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.1.2
Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
