14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years ago --- Quote Start --- Look at your board schematics. 1) Is there an clock output on an SMA connector? Eg., from an FPGA clock pin or from an on-board oscillator fanout buffer? 2) Is there a clock input on an SMA connector? 3) Connect board#1 -> board# 2 with an SMA cable from the clock output SMA to the clock input SMA. 4) The design on the board#1 (with the SMA clock output) should use an FPGA pin with the same clock as the output clock. The design on the board#2 (with the SMA clock input) should use the SMA input clock as the reference. Now both boards are synchronous. 5) The high-speed transceiver links will start in lock-to-reference, and then transition to lock-to-data mode. Since the data source and sink PLLs are locked to the same reference, you won't see any clock drift. --- Quote End --- Great advice! exactly what I am looking for. I think this will really helps. I will try this weekend and update the result then. Thanks a lot.
