14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years ago --- Quote Start --- If one board uses a 156.25MHz reference that is actually a few kHz high, and the other board uses a reference that is a few kHz low, then one board will send data to the other faster than ideal. The clock-and-data recovery (CDR) in the receiver will track the higher frequency, however, if you use a FIFO to cross clock domains between the recovered clock and the local clock, you will eventually get a FIFO overrun (or underrun in the case of a slower transmitter). Protocols like 10G take care of this by having protocol codes that can be added or deleted. If you are implementing FPGA-to-FPGA communications, then the system becomes simpler if you use a synchronous reference. You can implement this reference using an external synthesizer and send a copy of the signal to each board, or you can use one of your boards as the clock source and the other can receive a clock from the first, and use it for clocking its receiver logic. --- Quote End --- Dear Dave, How can I implement the synchronous reference clock? If you can provide some more details regarding the external synthesizer such as examples, materials,...I am thinking this is the problem for the board-to-board communication I am encountering now. Thanks
