14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years ago --- Quote Start --- If you do not have much RAM, then your synthesis time will increase dramatically. I suspect that is your problem. --- Quote End --- Thanks Dave. It was my mistake before. Actually, the compilation was done in my desktop instead of the server and it took long time because of the low RAM. The thing is that this design still cannot be compiled in the Server 2008. I generated the Qsys system in a XP PC and copied the design to compile in the Server, but it stopped at analysis and systhesis step without an error. Anyway, we are going to replace the OS soon. Probably, we will use Redhat Enterprise. Regarding the socket programming you mentioned before, I have no experience on this, if you can tell me some tools and are they OS dependent? For example if they work well in Windows? Thank you and Happy Easter! Best, PLMT.
