14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years agoDear Dave,
I just found out that our NIC with SFP+ connector is the second one you found: http://www.newegg.com/product/product.aspx?item=n82e16833120384 And it does only support Window Server among Windows OSs. We may have to decide whether: 1-Buy new NIC(s) that support Windows 7/vista or XP so that we can use Quartus II in Windows. But this seems to be an expensive choice. 2-Change to use Quartus II in Linux OS, but I did not have experience with this OS and this would be hard choice for me. 3-Keep using Windows Server 2008. But first, try to fix the issue for Qsys generation with On-chip memory cores. However, this is not a Quartus supported OS, so I don't know if I should try this direction. Do you have any further advice? I am more prone to the third option right now. Regarding the issue, you have suggested me to check the Java Runtime: --- Quote Start --- It looks like your script output stops right around the time Java is started. Perhaps Java on Windows Server 2008 is broken. --- Quote End --- I suspected that the current jre of Quartus has problems. So, I have installed newest Java 7 and replaced the content of C:\altera\11.1\quartus\bin64\jre64 with C:\Program Files\Java\jre7. But this does not help. If you have any further ideas about how to check and fix this issue? Thank you very much. PLMT
