14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years ago --- Quote Start --- You can see the problem I have during the process of generating HDL files for the Qsys system in the attached file. The generation hangs for ever with the last msg as "Info: Starting classic module elaboration." --- Quote End --- I've attached the output from Qsys under Windows XP. Its fine. It looks like your script output stops right around the time Java is started. Perhaps Java on Windows Server 2008 is broken. --- Quote Start --- I have thought of this option before, but I need to confirm that the problem comes from the OS first. The servers are not my personal PCs so reinstalling would be a second choice. --- Quote End --- You have paid for a full-subscription license for Quartus. Your bosses or sysadmins need to appreciate that the software needs to be installed in a supported OS. You will not get any response to requests for support until you are using a supported OS. Cheers, Dave
