14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years agoDear Dave,
Please find my comments below. --- Quote Start --- Here's a tutorial that shows you how to use the JTAG-to-Avalon-MM master component and Avalon-MM BFM components: http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial --- Quote End --- Thank you very much. I find it very useful and will try to study soon. I've just looked through the design and it has one On-chip SRAM. I am not sure if this works in Qsys. Because these days, I learnt to create designs for On-chip memory (both On-chip FIFO and RAM memory cores), but always the generation process hangs with the message "Starting classic module elaboration" in the step of "creating HDL design files for senthesis". I am using Quartus 11.0 and 11.1 and the error occurs whenever the design has On-chip memory core. If you can help to check this or give me a clue to fix the error. Sorry for putting this here:) --- Quote Start --- If your design fits in a Cyclone or Arria series device that has transceivers that operate to 3.125Gbps with a XAUI interface that uses 8/10B encoding, then you can interface to an external PHY (I think Vitesse has some) that will decode-and-reencode the data as 10.3125Gbps SFP+ (with 64/66B encoding). A lower-cost FPGA plus external PHY may be more cost effective than using a high-end FPGA. --- Quote End --- Maybe I will understand this later. For now, I am quite confused. By external PHY, do you mean something like the "Dual XAUI to SFP+ HSMC" board for connecting SFP+ modules in case of Stratix IV GX? As fas as I know, people has tested 10Gbps Ethernet with Stratix IV GT (but in 100G SIV GT dev board) in http://www.alterawiki.com/wiki/10g_ethernet_and_10g_base_r_phy_interoperability_hardware_demonstration_design. Acording to the block diagram, they connect directly to SFP+ Optical module without an external board or PHY. If you can help to correct my understanding and clarify? --- Quote Start --- It depends on what you have to store. If you are only testing, then you can use a PRBS generator to create a lot of random data. --- Quote End --- Testing with PRBS generator is what I want now. But, later on, I need to read data in terms of multimedia file like a movie file from host PC, store in some on-chip memory or buffer, then transmit in packets to other boards. So, I am wondering how should I do that and what is the most suitable solution. I wait for your advice also:) Thanks indeed for your time and explanation. I learnt a lot through this conversation. PLMT.
