14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years agoDear Dave,
Once again, thank you very much for your very useful advice. --- Quote Start --- My recommendation would be to take the XCVR debug example, which works, and simulate it. That'll allow you to probe a working design. --- Quote End --- Yes, this is my plan. However, there is not available example for 10GBASE-R, and I am trying to create generator/checker component with XGMII data width instead of using the existing Avalon ST gen/checker. So, I need to write the component in verilog and then add them to Qsys library. Once I have those, I can create the complete design that includes the 10GBASE-R, the generator/checker. The JTAG to Avalon Master Bridge has a master interface to control the three components so that I can run design on devices and use XCVR Toolkit to test the signal quality. If you have any suggestion/comment about this intention? --- Quote Start --- I assume this is the 10GBASE-R IP you are looking at: http://www.altera.com/products/ip/iup/ethernet/m-alt-10gbase-r-pcs.html --- Quote End --- Yes, exactly the document I have studied. I also refer to a hardware demonstration in http://www.alterawiki.com/wiki/10g_ethernet_and_10g_base_r_phy_interoperability_hardware_demonstration_design Actually, this works with different board and I changed the pin assignment for my device. But I got some errors during recompilation. I will fix this next days. Do you suggest other materials or design examples? --- Quote Start --- You should synthesize to see how much logic the PCS layer is using. Given that the Stratix IV GT might not be a good use of resources, have you considered using a GX device with an external PHY? --- Quote End --- Frankly, I have not considered this. Can you put some more details as it looks very important. Regarding to the resources of my boards and devices, I also wonder that in case I need memory to store data for board-to-board communication application, which kind of memory I can use? As far as I understand, both the on-chip memory (TriMatrix memory includes 640-bit MLABs, 9-Kbit M9K, and 144-Kbit M144K blocks) and on-board memory (64-MB synchronous flash) are quite limited. Is it possible for my board to use external memory and if yes, how to do so as I do not see this infos in the reference manual. Can you please help to confirm my understanding and give me some explanation also? Unfortunately, I cannot change my devices (I am not the one who decides). I need to do everything with these boards. And how can I check the amount of resource used for PCS only? As I know the compilation report provides the summary for whole design rather than each sublayer. --- Quote Start --- What you really should be doing then is getting the PHY working in the simulator so that you can simulate while working on your custom logic. --- Quote End --- I will try to do this next days. I see the importance of this step. Thank you very much for this timely advice. Best, PLMT
