14 years agoExample designs for communicating two Altera boards
I am looking for example designs or tutorials showing how to communicate two Altera boards using simple protocols. The purpose is to see how the two devices interact by transmitting data back and for...
14 years agoMany thanks to Dave and please find my answers as following:
1-What are you looking to test? The transceivers? Yes, the main purpose is to to test transceivers, in particular with the Altera PHY IP cores. But besides these, I want to know how to create a design for two boards to communicate one another using some simpler protocol than the PHY IP cores. The data rate can be any not greater than 11.3Gbps 2-What have you tried so far? I have tried to test XCVR with On-chip debugging design examples provided by Altera. Then I created similar designs with Lowlatency and Custom PHY for various data rates using Qsys. However, I would like to have a 10Gbase-r PHY design and I could not create this in Qsys. I don't know if it is possible to create such design by using available components in Qsys. 3-Do you know how to configure the ALTGX and ALGX_RECONFIG components? I have general idea about the ALTGX and ALTGX_RECONFIG but have not ever used these as I want to try designing with Qsys first. 4-What do you have in addition to the GT boards? Do you have break out cables? A synthesizer to provide a common clock between the boards? I have SMA cables for physical connection between the two boards. For a synthesizer to provide the common clock, if you can make this clearer? Thanks.
