14 years agoevolvable hardware
I need to start a small project for evolvable hardware using some Altera device or development kit. The idea is to create optimised hardware using a genetic algorithm which outputs a solution for the...
14 years agoI don't know about genetic algorithms but just a thought. if you have multiple switches to choose one among various preconfigurations, wouldn't that work for a small scale circuit. By various configurations I mean you enable or disable preconfigured sections and choose from depending on your feedback.
You can also have multiple fpga images but limited to your configuration scheme. The images, however need to be generated through the standard methodology.
