19 years agoevaluating ressources saving between differents families
Hi! I'm trying to evaluate the amount of logic cells used for different standard operations (like addition, multiplication..) for differents Altera devices. I particurlarly want to know th...
19 years agoOne (obvious) method could be to make some test designs in Quartus and compare. If you know quartus, its simple and its easy to swicth target. If you dont have Quartus you can download web edition for free, but you will of course have to spend time learning to use it!
Just had a quick look in megawizard and that says Resource result is for 8x8 mult Cyclone: 117Lut's Cyclone II, III: 1 Dsp-9bit block Stratix " ", II, III: 1 Dsp-9bit block Resource result is for 16x16 mult Cyclone: 357Lut's Cyclone II, III: 2 Dsp-9bit block Stratix " ", II, III: 2 Dsp-9bit block Resource result is for 32x32 mult Cyclone: 1221Lut's Cyclone II, III: 8 Dsp-9bit block+110Lut's Stratix " ", II, III: 8 Dsp-9bit block
