16 years agoethernet doubt
hi all, i do not know much about Ethernet concept... i am using EP2S60F672C4 and RTL8201CL (PHY device) and i want to implement 10/100Mbps MAC using NIOS-2. i am trying to use Trip...
16 years agoNo the flash isn't necessary. It is used in the sockets server example to get the MAC and IP addresses, but you can remove the code that uses the flash and hard-code those yourself.
You don't need to do anything to have the board reply to pings, the Interniche TCP/IP stack will do this automatically.
