16 years agoethernet doubt
hi all, i do not know much about Ethernet concept... i am using EP2S60F672C4 and RTL8201CL (PHY device) and i want to implement 10/100Mbps MAC using NIOS-2. i am trying to use Trip...
16 years agoYou need the memory to store the packets, and the DMAs to transfer the packets between the memory and the TSE core.
You don't have to use a 100MHz clock, but it is recommended to have something fast enough if you don't want to loose too much time in the transfers.
