16 years agoEthernet connectivity using Cyclone III development board
Hello, I am new in designing Ethernet connectivity and in developing software using NIOS II. The Ethernet hardware system is successfully built in Quartus II and it is similar to the desi...
16 years agoOther question:
Do you need to send/recv raw ethernet frames or do you need tcp/ip connectivity? In the first case you can simply rely on the specific Ethernet mac driver, or build your own. In the second case you'd need an OS (RTOS, Linux, ... ) and appropriate stack software module (NicheStack, lwip, ...)
