19 years agoESD test on cyclone 2
Hi. We have board designed around Cyclone 2 in 240 pin package(QFP). On this board beside fpga is located memory(DDR RAM) and lvds converters. In the order to done esd test I implemented si...
19 years agoFrom here, it is hard to suggest solutions.
To me it should be possible to "record" the bahavior of the power lines and signal lines with a oscilloscope when ESD tests are taking place. You might be able then to decice, if it is just an error caused by instable power voltage, as I assume. In case of peeks on the lines, additional suppressor diodes in beneath of the chip might help.
