14 years agoError:Connected system timestamp not found on target at expected base address.
Hi, I'm fairly new to FPGA programming, please bear with me. I tried to use Nios II and Quartus II 10.1 on Windows 7(64 bit) to programme a Altera DE2-70 board. I basically followed the...
9 years agoIf I had such problems often the reason was a missed clock or active reset. Check if the clock for Nios is running and the reset is deasserted.
Have you used the right .sopcinfo file in your Nios BSP project?
