14 years agoError:Connected system timestamp not found on target at expected base address.
Hi, I'm fairly new to FPGA programming, please bear with me. I tried to use Nios II and Quartus II 10.1 on Windows 7(64 bit) to programme a Altera DE2-70 board. I basically followed the...
14 years agothank you for your suggestion
I tried your command and it gives me the following error % [processor_stop $mast] error: java.lang.RuntimeException: com.altera.systemconsole.internal.plugin.jtag.oci.Nios2DebugException: Target is broken and needs to be reset while executing "processor_stop $mast" invoked from within "[processor_stop $mast] I guess the problem might come from reset which is not set to high in my SOPC since the board I think is active low. But How may I set it high? Thank you.
