14 years agoError:Connected system timestamp not found on target at expected base address.
Hi, I'm fairly new to FPGA programming, please bear with me. I tried to use Nios II and Quartus II 10.1 on Windows 7(64 bit) to programme a Altera DE2-70 board. I basically followed the...
14 years agoHi Daixiwen:
I tried your suggestion. It gives me some new clues which I regretfully do not know how to understand. First I tried to implement the instructions in the system console and here is the result % set mast [lindex [get_service_paths master] 0] /connections/USB-Blaster on localhost [USB-0]/EP2C70@1/[MFG:70 ID:34 INST:0 VER:3]/nios2_0 % open_service master $mast % master_read_32 $mast 0 1 error: java.lang.RuntimeException: com.altera.systemconsole.internal.plugin.jtag.oci.Nios2DebugException: Can't do this while target is running while executing "master_read_32 $mast 0 1" % master_read_32 $mast 4 1 error: java.lang.RuntimeException: com.altera.systemconsole.internal.plugin.jtag.oci.Nios2DebugException: Can't do this while target is running while executing "master_read_32 $mast 4 1" But I have closed the SOPC and the programmer, I am very new and I really do not understand why it is running. Then I tried to look at the SOPC but I did not find the timestamp connection. I have attached my Printout of the SOPC file Thank you very much for your time and attention.
