14 years agoError:Connected system timestamp not found on target at expected base address.
Hi, I'm fairly new to FPGA programming, please bear with me. I tried to use Nios II and Quartus II 10.1 on Windows 7(64 bit) to programme a Altera DE2-70 board. I basically followed the...
14 years agoYes it looks like there is something in the FPGA that is working, at least. Be sure you don't close the opencores evaluation window as it will make the CPU stop and won't let you read the system ID.
You can try and open System Console and use it to read directly the two registers from the System ID component and check what you get back. You can start withset mast 0]
open_service master $mastand thenmaster_read_32 $mast 0 1should give you the ID and master_read_32 $mast 4 1should give you the timestamp. Are you sure the Timestamp ID component is connected to the Nios CPU's data master? Is it on a different clock domain? If yes is this clock running?
