14 years agoError:Connected system timestamp not found on target at expected base address.
Hi, I'm fairly new to FPGA programming, please bear with me. I tried to use Nios II and Quartus II 10.1 on Windows 7(64 bit) to programme a Altera DE2-70 board. I basically followed the...
14 years agoHi Daixiwen:
Thank you for your reply. I am pretty sure that I have compored and configured the FPGA and used the _time_limited sof file. When I use the Nios2 command shell: nios2-terminal it shows: nios2-terminal:connected to hardware target using JTAG UART on cable nios2-terminal:"USB Blaster [USB]", device 1, instance 0 nios2-terminal:<Use the IDE stop button or Ctrl+C to terminate> I guess the device is correctly connected and should be able to download the hardware program. But it still gives me the error about system id and timestamp mismatch. Is there any other possible bugs that could result in such error? Thank you! Jia Yang
