14 years agoError with Virtual JTAG
Hi everyone,
I created a Virtual JTAG in MegaWizard Plug-In Manager and its instant below:module counter (clock, my_counter);
input clock;
output my_counter;
reg my_counter;
always @ (posedge clock)
if (load && e1dr) // decode logic: used to load the counter my_counter
my_counter <= tmp_reg;
else
my_counter <= my_counter + 1;
// Signals and registers declared for VJI instance
wire tck, tdi;
reg tdo;
wire cdr, e1dr, e2dr, pdr, sdr, udr, uir, cir;
wire ir_in;
// Instantiation of VJI
Virtual_JTAG Virtual_JTAG_instant(
.tdo (tdo),
.tck (tck),
.tdi (tdi),
.tms(),
.ir_in(ir_in),
.ir_out(),
.virtual_state_cdr (cdr),
.virtual_state_e1dr(e1dr),
.virtual_state_e2dr(e2dr),
.virtual_state_pdr (pdr),
.virtual_state_sdr (sdr),
.virtual_state_udr (udr),
.virtual_state_uir (uir),
.virtual_state_cir (cir)
// Declaration of data register
reg tmp_reg;
// Deocde Logic Block
// Making some decode logic from ir_in output port of VJI
wire load = ir_in && (~ir_in);
// Bypass used to maintain the scan chain continuity for
// tdi and tdo ports
bypass_reg <= tdi; // Error here
// Data Register Block
always @ (posedge tck)
if ( load && sdr )
tmp_reg <= {tdi, tmp_reg};
// tdo Logic Block
always @ (tmp_reg or bypass_reg)
if(load)
tdo <= tmp_reg;
else
tdo <= bypass_reg;
endmodule and I got this error: Error (10170): Verilog HDL syntax error at Virtual_JTAG_instant.v(46) near text "<="; expecting ".", or "("
Can anyone help me solve this issue? :D1 Reply
You're using VHDL syntax. Use Verilog syntax:
Cheers, Daveassign bypass_reg = tdi;
