9 years agoError when using University Program VwF
I'm using Quartus 16.1 I want to simulate, but when I press Run functional simulation this error occur " Warning (18236): Number of processors has not been specified which may cause overloa...
9 years agoYou need to do these five things for Quartus simulation;
1) Tell Quartus to use ModelSim-Altera for the simulation tools (Assignments - EDA Tool Settings - Simulation). 2) Tell Quartus to generate a netlist for functional simulation (Assignments - EDA Tool Settings - Simulation - More EDA Netlist Writer Settings - Generate Functional Simulation Netlist - ON). 3) Tell Quartus to use VHDL for the simulation netlist (Assignments - EDA Tool Settings - Simulation - Format for Output Netlist - VHDL) 4) Tell Quartus where to put the simulation netlist (Assignments - EDA Tool Settings - Simulation - Output Directory). This is usually the "simulation" folder. 5) Tell the simulator (in the simulation waveform editor) to use VHDL for the netlist language (Simulation - Simulation Settings - Use VHDL). Good Luck.
