18 years agoerror message: "can't verify device number 1"
Hi, I am the newest member here. I am getting an error message "can't verify device number 1". The device is EPM1270T144C5. It was programing OK for a while, then the error came up. M...
18 years agoHello Dan,
unfortunately I can't see from a distance what's going on in your circuit, and may be, I would have the same difficulties with the circuit at my fingetrtips. delayed was referring to the fact, that the error occured after several programming cycles, if I understood right. To verify, that the design isn't damaging the flash by excessive write or erasure requests, I would disconnect the respective control lines and try with a new device. If this kind of design problems can be excluded, I would return to possible hardware issues. There must be something specific to your present hardware. Of course, individual parts may be defective, respectively have been damaged by solder/desolder or ESD events. So it may be misleading to base the conclusions on the behaviour of a single part. Regards, Frank
