18 years agoerror message: "can't verify device number 1"
Hi, I am the newest member here. I am getting an error message "can't verify device number 1". The device is EPM1270T144C5. It was programing OK for a while, then the error came up. M...
18 years agoHi again,
I need to make a big correction. The device DOES work when I program the CFM section only. It does require to turn the power off then on, but then it works. I did not see it, because normaly, I see all sorts of LED's On and the front panel switches function as well after programing. When I program the CFM only, the device only work after power off then on. But this is progress. I would think that vthe JTAG is working, and I have an issue with the user flash memory (UFM). Now I need to figure why I get a "can't verify device" when trying to program the UFM. I am slightly encouraged, but still do not know what the problem is. Regrads Dan
