18 years agoerror message: "can't verify device number 1"
Hi, I am the newest member here. I am getting an error message "can't verify device number 1". The device is EPM1270T144C5. It was programing OK for a while, then the error came up. M...
18 years agoHello again,
I looked in the JTAG literature, chapter 11 in the IN-System Programibility Guidelines for MAX II devices. It sugested to check the TCK, and have it pulled down to Ground with 1K. According to the scope (100MHz bandwidth), the signals are very clean, no overshoots, no double pulses... I did not see any referance to "startup voltages" at power up. I will try to find it. Meanwhile, I figured out the following: In the programing window, there are 3 rows. The top row specifies files (for the *pof), device, checksum, user code, the there are the boxes to check mark - program, verify, blank check, security and earse. The second row has check marks for CFM, and the third row for UFM. My programer completes the program and verify tasks when I check the CFM boxes only. The programer fails ("can't verify device number 1") when I try to program the UFM only. It can not everify the UFM. The device does not function after I program the CFM (with or without verify). I guess there is some reason for it, but I do not undersatnd it. I thought that programing the CFM will have the user flash section work, and the user flash memory not work, but that is not the case here. I do use the UFM, but I tried programing other files, as simple as a single input and output with an inverter between, and that does not work either - same error message. My second board (not too populated yet, with only Altera, 3.3V regulator and bypass caps) does program. But I am nervous, because the first board programed fine about 3 dozen times before failing. In fact, it came to life for about 3 program cycles when I changed the IC. I programed the second board about 10 times, to see that it is working. So far it is OK. I will have the other parts soldered, but I am nervous about it. The power supply is the same for both boards, and has been used for many programing tasks. I am still very confused. The layout is good, many bypass caps and a 3.3V linear regulator (from a clean 5V source)... I wonder if the ability to program the UFM means that the JTAG is working fine, and the problem is elsewhere. The device is not heating up at all, so I would rule out latching. Regards Dan
