8 years agoError loading shared libraries when setting up a float license
Hello friends, Thanks for opening this post. Currently, I have an issue with setting up our floating license for Quartus PRIME Pro (a license .dat file also bundles with some other license...
8 years ago --- Quote Start --- I ran into this issue today although I'm running the tools and license server from the same machine. I just updated my LD_LIBRARY_PATH to point to the missing library. You could try copying the missing library across to your license server? "export LD_LIBRARY_PATH=/eda/intelFPGA_pro/18.0/quartus/linux64:$LD_LIBRARY_PATH" --- Quote End --- Hello Sjalloq, Thank you very much for your reply. Your approach makes sense to me. For that, I have installed Quartus PRIME Pro 17.1 (it does contain folder /quartus/linux64 and various .so files) and set up the PATH accordingly. However, the specific file alterad is looking for is libSafeString.so and it is not in that folder. I wonder whether you can help me see whether you have that file in your folder, given that yours is 18.0? Best regards, Taihai
