8 years agoError loading shared libraries when setting up a float license
Hello friends, Thanks for opening this post. Currently, I have an issue with setting up our floating license for Quartus PRIME Pro (a license .dat file also bundles with some other license...
8 years agoI ran into this issue today although I'm running the tools and license server from the same machine. I just updated my LD_LIBRARY_PATH to point to the missing library. You could try copying the missing library across to your license server?
"export LD_LIBRARY_PATH=/eda/intelFPGA_pro/18.0/quartus/linux64:$LD_LIBRARY_PATH"
