8 years ago
Error in Quartus' Simulation Editor
I'm doing a project using Quartus Prime 18 and today I couldn't compile the waveform file (.wvf) - even though I could do it before. Tried with other Quartus projects and the results are the same, any ideas? The error code I get from the flow progress is the following:
Determining the location of the ModelSim executable...
Using: c:/intelfpga_lite/18.0/modelsim_ase/win32aloem/
 To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
 **** Generating the ModelSim Testbench ****
 quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off MISC -c MISC --vector_source="C:/Users/cufar/Documents/Universidad/ElectronicaV/Trabajos Practicos/MISC/Waveform.vwf" --testbench_file="C:/Users/cufar/Documents/Universidad/ElectronicaV/Trabajos Practicos/MISC/simulation/qsim/Waveform.vwf.vt"
 Info: *******************************************************************
 Info: Running Quartus Prime EDA Netlist Writer
     Info: Version 18.0.0 Build 614 04/24/2018 SJ Lite Edition
     Info: Copyright (C) 2018  Intel Corporation. All rights reserved.
     Info: Your use of Intel Corporation's design tools, logic functions
     Info: and other software and tools, and its AMPP partner logic
     Info: functions, and any output files from any of the foregoing
     Info: (including device programming or simulation files), and any
     Info: associated documentation or information are expressly subject
     Info: to the terms and conditions of the Intel Program License
     Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
     Info: the Intel FPGA IP License Agreement, or other applicable license
     Info: agreement, including, without limitation, that your use is for
     Info: the sole purpose of programming logic devices manufactured by
     Info: Intel and sold by Intel or its authorized distributors.  Please
     Info: refer to the applicable agreement for further details.
     Info: Processing started: Thu May 24 18:47:32 2018
 Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off MISC -c MISC --vector_source="C:/Users/cufar/Documents/Universidad/ElectronicaV/Trabajos Practicos/MISC/Waveform.vwf" --testbench_file="C:/Users/cufar/Documents/Universidad/ElectronicaV/Trabajos Practicos/MISC/simulation/qsim/Waveform.vwf.vt"
 Warning (18236): Number of processors has not been specified which may cause overloading on shared machines.  Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
 Completed successfully.
 **** Generating the functional simulation netlist ****
 quartus_eda --write_settings_files=off --simulation --functional=on --flatten_buses=off --tool=modelsim_oem --format=verilog --output_directory="C:/Users/cufar/Documents/Universidad/ElectronicaV/Trabajos Practicos/MISC/simulation/qsim/" MISC -c MISC
     Info: Processing started: Thu May 24 18:47:34 2018
 Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=on --flatten_buses=off --tool=modelsim_oem --format=verilog --output_directory="C:/Users/cufar/Documents/Universidad/ElectronicaV/Trabajos Practicos/MISC/simulation/qsim/" MISC -c MISC
 Info (204019): Generated file MISC.vo in folder "C:/Users/cufar/Documents/Universidad/ElectronicaV/Trabajos Practicos/MISC/simulation/qsim//" for EDA simulation tool
 Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 1 warning
     Info: Peak virtual memory: 4638 megabytes
     Info: Processing ended: Thu May 24 18:47:35 2018
     Info: Elapsed time: 00:00:01
     Info: Total CPU time (on all processors): 00:00:01
 **** Generating the ModelSim .do script ****
 C:/Users/cufar/Documents/Universidad/ElectronicaV/Trabajos Practicos/MISC/simulation/qsim/MISC.do generated.
 **** Running the ModelSim simulation ****
 c:/intelfpga_lite/18.0/modelsim_ase/win32aloem//vsim -c -do MISC.do
 Reading C:/intelFPGA_lite/18.0/modelsim_ase/tcl/vsim/pref.tcl
#  10.5b
#  do MISC.do
#  ** Warning: (vlib-34) Library already exists at "work".
#  Model Technology ModelSim - Intel FPGA Edition vlog 10.5b Compiler 2016.10 Oct  5 2016
#  Start time: 18:47:36 on May 24,2018
#  vlog -work work MISC.vo
#  -- Compiling module MISC
#  -- Compiling module hard_block
#  Top level modules:
#      MISC
#  End time: 18:47:36 on May 24,2018, Elapsed time: 0:00:00
#  Errors: 0, Warnings: 0
#  vlog -work work Waveform.vwf.vt
#  -- Compiling module MISC_vlg_vec_tst
#      MISC_vlg_vec_tst
#  End time: 18:47:37 on May 24,2018, Elapsed time: 0:00:01
 Errors: 1, Warnings: 0
 RPC(simulator): channel sock724 read error: (134) socket is not connected (line 804)
 ** Fatal: Kernel lost connection to front end process.
 ** Fatal: (SIGSEGV) Bad pointer access. Closing vsimk.
 ** Fatal: vsimk is exiting with code 211.
 Exit codes are defined in the "Error and Warning Messages"
 appendix of the ModelSim User's Manual.
As you see there is an error of 'socket is not connected', I'm wondering what Socket this is talking about since this is a pure software simulation.
    Thank you for your reply. Turns out the antivirus was blocking the application that run the waveform university program to simulate signals. I could solve the problem turning it off.
    Can you share your design file(.qpf)?
    In which all tools you have tried to simulate?
    Anand Raj Shankar
