11 years agoerror in pin planner
hello all, i got one error in pin planner that is Error (176172): Can't place node "hsync_n" -- node is a differential I/O node. with this post i am attached .Qsf file. i dont know why thi...
11 years agohttp://www.alteraforum.com/forum/showthread.php?t=46925 (http://www.alteraforum.com/forum/showthread.php?t=46925)
As per my response to your other thread open with the same question... A quick look at the .qsf you posted shows a conflict between the 'hsync_p' & 'hsync_n' signals. One is 1.8V, the other 2.5V. I think you should be generating hsync as a differential signal. However, your qsf shows different single ended I/O standards for each half of the pair. If you still need help let me know. Happy New Year, Alex
